RCU Forums - View Single Post - Magic VF3 building thread
Old 03-05-2008 | 11:50 PM
  #48
Don Szczur's Avatar
Don Szczur
Default RE: Magic VF3 building thread
Dremel out front of chin cowl for engine cooling, then dremel out clearance for YS connecting rods/pump. Trial fit chin cowl. Guess what, yes, it fits just about perfect...
Trim balsa from around back rear lower deck. Sand flush with a block to make sure its straight and to keep from sanding into the foam mating surface.
Mark the spot where you cut the taper in the front to conform to the rear chin cowl.
ID:	895931   Click image for larger version
ID:	895932   Click image for larger version
ID:	895933   Click image for larger version
ID:	895934   Click image for larger version
ID:	895935   Click image for larger version
ID:	895936   Click image for larger version
ID:	895937   Click image for larger version
