RCU Forums - View Single Post - Modeltech Saphir Build
Old 03-06-2008 | 07:21 AM
zeuglodon's Avatar
zeuglodon
Default RE: Modeltech Saphir Build
I wanted to simplify the setup process so I modified the belly pan attachment to consist of 2 dowels at the leading edge and one 4-40 bolt at the rear into a "T" arrangement at the wing hold down plate. I also put one of those spring clips on the 4-40 bolt so it will stay in the belly pan when the pan is off the fuse.
ID:	896047   Click image for larger version
ID:	896048   Click image for larger version
