RCU Forums - View Single Post - Tail going counter-clock -- servo is already maxed out
Old 03-06-2008 | 07:15 PM
BladeCX2Two
Default RE: Tail going counter-clock -- servo is already maxed out
aland25- yes i did put another brand new servo on it and it does the same exact thing. But thanks for your reply though. I checked the pitch on it tonight and in normal flight mode, at 50% throttle she has about 5* of pitch. At full throttle in 3D mode, she has about 9 1/2*... at mid stick in 3D mode, she is spot on 0*. I'm pretty happy with those numbers.
My Align 315 blades and trex tail blades shipped. I might have them as early as Saturday.
I flew it tonight a whole batteries worth. Other than having to give it constant tail input, It flies very nice. I don't know if it's more stable because of the 325 blades or just the Align blades period. To give you an idea of how much tail input I have to give it, I have to hold it about 1/3 of the way between neutral position and full right. Not bad but until it's fixed, I don't feel comfortable in doing anything except for hovering around. I'll first try the trex tail blades with the current 325's I have on it. If that don't cure it, then I'll put the Align 315's on.
Thanks again.
