RE: My T2A
I talked to Jerry Nelson about sanding primers. He said when you wet sand you round over the edges that you make, dry sanding will leave sharp edges giving the paint something to hold on to. I went to 220 grit dry and it took care of my sticking problems. I will still wet sand my color coat to knock down the edge then LIGHTLY sand w/ 220 before the clear coat.
