RCU Forums - View Single Post - Building the Cowboy
Old 04-26-2003 | 01:21 AM
im_a_rcav8r
Default Building the Cowboy
humm the Plane may be a hard one... I have not seen that one before. As for the engine, do you know what kind of carb it has? Most engines will fire up with 3 or 4 turns on the mixture. May be a bit rich but it should fire. You may want to have some one who knows glow engines show you how to tune it though. Tuning can be done by ear or with a Tachometer. You want to adjust the mix lean to get max RPM then go about 1/4 or 1/2 turn richer. More if the motor is new or it is real hot out.
