RE: Glow plug draw?
On second thought, you could try one of the ignighters FrugalFlyer used, You would probably need to run a common ground wire to each engine. Don't run a ground from the ignighter to each engine, it will eat your batteries up. The biggest difference between his set up and yours is that all his glow plugs had the same ground.
