E-Flite AT-6 Texan 25 ARF
E-flite raises the bar with their first Platinum Series ARF; the legendary [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFL4500]AT-6[/link] “Texan” trainer used by the U.S., and its allies, from WWII through the late 1960s. The E-flite Platinum Series delivers superior, enhanced features and meticulous attention to detail...right out of the box! It features a level of scale detail that is exceptional for an ARF of this size. You get all this realism without having to spend weeks of building, covering and painting. Just about everything has been done for you before you even open the box. All that’s left to do is a few hours of final assembly and radio installation. The electric power system will keep this beautifully appointed warbird trainer clean and vibration-free...one reliable flight after another.
Key Features:
* 90% complete—just a few hours of assembly and you’re flying
* Lightweight construction
* Fully sheeted airframe to help maintain scale appearance
* Covered in genuine Hangar 9 UltraCote
* Retract- and flap-ready right from the box
* Optional Robart retractable landing gear is available separately
* Factory-painted fiberglass cowl and scale scoops
* Scale finish and markings
* Firewall designed to accept E-flite Power 25 BL Outrunner Motor
* Plug-in outboard wing panels for convenient transport and storage
* Easy-access magnetic battery hatch
* Extremely accurate scale outline worthy of the most demanding scale modelers
* Wing utilizes two Selig airfoils for optimum flight performance at all speeds
Specifications:
* Wing Span:54" (1370mm)
* Overall Length:39" (990mm)
* Wing Area:455 sq in (29.4 dm)
* Flying Weight:3.9 - 4.5 lbs (1.8 - 2.0 kg)
* Motor Size:Power 25
* Radio:6 channels w/7 micro servos
* Servos (7) JR Sport MC35's, (1) JR Sport RT88 for optional retracts
* Trim Scheme Colors:Ultracote Gray with red and yellow trim
* Prop Size:APC 12x8E
* Hardware Included:yes
* Speed Control :40 - 60 Amp
* Recommended Battery:11.1 V 4200 mAh 3-cell Li-po
* Scale:Stand off Scale
* Approx. Assembly Time:6 - 8 hours
