RCU Forums - View Single Post - E-Flite AT-6 Texan 25 ARF
Old 03-07-2008 | 08:40 AM
Greg Covey's Avatar
Greg Covey
Default RE: E-Flite AT-6 Texan 25 ARF
The AT-6 25e comes out of the box with all kinds of details that have been finished for you, including a factory-painted fiberglass cowl, air scoops, dummy radial engine, painted canopy and pilot, scale strut covers, scale trim scheme and much more. Even the Texan’s sheeted airframe compares favorably to the full-scale aircraft which helps maintain the model’s strict scale appearance and strong flight performance.
Scale airfoils were used to maintain the exact scale outline of the AT-6 Texan's tail surfaces to include counterbalances. Both the elevators and rudder are pre-hinged out of the box and ready for installation. One pilot is included with the kit along with cockpit decals. An additional pilot is available separately (EFLA150). Genuine Hangar 9® UltraCote® provides a durable, refined finish.
The scale split flaps are operational and pre-hinged right out of the box. Using a unique pin interlock system, they plug together and operate using only 2 servos. Optional E-flite retracts (EFL4515) are available that have been specially designed for the AT-6 25e. Making these mechanical retracts functional is as simple as installing a servo and connecting the pre-bent wire linkages.
The 50 page manual is loaded with photos, instructions, and excellent advice from people that have actually assembled the model.
ID:	896942   Click image for larger version
ID:	896943   Click image for larger version
ID:	896944   Click image for larger version
ID:	896945   Click image for larger version
ID:	896946   Click image for larger version
ID:	896947   Click image for larger version
ID:	896948   Click image for larger version
