RCU Forums - View Single Post - Flaps on six channel AR 6200 and DX7
Old 03-07-2008 | 08:56 AM
CGRetired's Avatar
CGRetired
Default RE: Flaps on six channel AR 6200 and DX7
Well, no, you can use a Y connector for the ailerons too. So, you can feed your ailerons to the aileron channel using a Y cable to the two servos, and the AUX1 channel for the Flaps also using a Y cable for that.
The aileron operation depends on how you connect your linkage as do the flaps. My drawing I added to my reply above shows how this is done. I've done it on two aircraft and it works just fine.. even though I never use the flaps.
CGr.
