RCU Forums - View Single Post - balancing a prop
Old 03-07-2008 | 10:00 AM
Rufcut
Default RE: balancing a prop
Seems like all prop manufacturers recommend balancing, so I do it using a magnetic type like CGR described. Usually they aren't very far out of balance. I never try to shave or sand the prop however. I always spray clear acrylic on the light side instead. The Master Airscrew website says that if a piece of masking tape 1" x 1" or less in size applied to the tip of the light side makes it balance or makes it the heavy side then you are within tolerance.
Rufcut
