RE: Eletronic engine syncronizer **SUPPORT **
You've got enough going on that it is probably best that we speak by phone when you are at the unit. I have a few simple tests I want you to run (see if the problem follows the sensor). I have only had 1 out of 1000 sensors turn out to be bad so far and it was because the cable company reversed the red and black wire in the male connector. So I want to get to the bottom of this problem.
