Fuel Question
You can, but you will have lots of oil because helis need much lubrication - they don't need to move in forward motion all the time, so they do not get enough cooling. The extra lube is there just for helis. You can run your engine on it but you may not get the most power out of it. Be prepared to run it a little bit leaner.
