GLASSING SNAFU
Howdy, as usual [with F/G work] I came up with a 99% good result. Too bad that isn't good enough. [&o]
This plane is going to be a "fun scale" .074 powered Blackbird, so keeping the weight down to minimum is important.
I brushed on a primer coat of finishing resin on the foam and gave it a few days to cure, then sanded off the fuzz. The build up looked good enough to go for the next layer to be with 1.5- 2 oz cloth. I guess I was wrong. The cloth laid down real nice as I was working it, but the following day the results I have with all the little air sacks of loose cloth leave me shaking my head.
How should I fix this mess?
