RE: GLASSING SNAFU
if you're trying to get it light you should sheet it with 1/16" balsa and use covering. you could also use 3/4oz glass over the sheeting and then paint but the iron on covering is by far the lightest choice. the sheeting and monokote would weight less then the finish resin that soaked into the foam on your 'Primer' coat.
