Phoenix Atlantis ARF Pattern Plane
Hey Richard, I've just bought the same plane. Can you help me with a couple of questions please:
1. The plans don't show how the main wing is mounted and while the bolts are solid I'm afraid the little plastic sleeves that you mount in the wing might pull right through the wing. How did you do yours?
2. How is the covering holding up? Did you need to give it a once over before you flew it?
3. There is a little bag of balsa bits in the box that doesn't seem to have a home. What did you do with this stuff?
4. How are landings, pretty quick or reasonably tame? Did you set up flaperons, if so how big was the movement you allowed?
Appreciate your help.
Simon
