Phoenix Atlantis ARF Pattern Plane
Hi Richard,
Thanks for the feedback, much appreciated. I didn't quite undertsand what you meant by 'cut the covers' with regards to mounting the servo conventionally - I just screwed the servos directly into the little raised panel, hope this is right!!
I will steal your ideas for reinforcing the wing nuts and locking down the covering but I'm going to stick with the existing push rods at present and reinforce with carbon fibre and just see how it goes. I will also copy your idea and put a couple of ply panels in to limit the flex of the pushrods. I reckon this arrangement will go ok given I'm only using an FX46 compared to your '50.
I fly at PRAMS and TMAC which are both great places, the latter isn't far from work so I can fly there in the mornings which is handy. You?
Again, thanks for the feedback.
Simon
