RCU Forums - View Single Post - Astro Blinky!
Old 03-07-2008 | 10:41 PM
Missileman's Avatar
Missileman
Default RE: Astro Blinky!
Just mind the polarity. There is a + and - on the board, use the most negative pin.
What I mean is. The blinky has 6 or 7 pins, if your battery has a 3 pin balance connector use the 3 pins closest to the - mark with the black wire closest to the -.
You will be happy with it.
