RE: BME .90 (15 cc) Super Tigre conversion
Hi all,
I am having idling issues with my BME.90. Everytime I think I have sorted it out (or say found something) it's the same, get's unstable below 2950RPM. I need her to be at 2200RPM, tried 15 x 6 (nylon) instead of the 14 x 6 (wood) that I was using, nothing much in terms of an improvement here. I have played with the needles (either way) often getting it back to factory set. Honestly, I thought I would put a OS carb, glow plug and run her with Methanol. That would certainly be the most expensive .90 2 stroke. I might do just that, but I want to give it the best possible shot before doing so. SO please suggest as many possibilities. Also will it run on glow fuel, if I replace the spark plug to glow. What to do about the crank case pressure tap then?
Thanks for your replies,
regards,
Gyri
