RCU Forums - View Single Post - Tail going counter-clock -- servo is already maxed out
Old 03-08-2008 | 07:30 PM
BladeCX2Two
Default RE: Tail going counter-clock -- servo is already maxed out
Well guys-- My Align 315 fiber blades and tail blades showed up today. I immiedately tried out the tail blades. Had to thin them out a bit as the stock esky ones are thinner. Took it outside and SAME THING, nose to the left. The Align 450 tail blades are probably only 3/16" longer than Esky... So then I put on the 315mm blades and kept the trex tail blades on. SAME THING, nose to the left. Servo was as far forward as I could go without hearing that it was skipping teeth.
Needless to say, I just figured out what the problem was. I had the linkage for the tail hooked up on the outside of the white servo bell horn. It supposed to be on the inside of it, so the linkage is acutally between the tail boom and the bell horn. On my heli, you could actually see that linkage curve downwards. This was creating a great deal of bindage. I just found this while I was paging thru the book looking at pictures. Now I sit with lots of extra tail blades and 3 sets of Align blades. That's the good that came out of it.
Flies like a top now. Actually had to move the servo back just a hair.
