RE: Help identifying old plastic pattern plane
Gluing plastic always seems to be a bit of a pain. With plastic, a solvent "weld" is the best method, but there are so many types of plastic finding the correct solvent is hard. If you use epoxy, make sure you scuff the area you are going to repair, otherwise it'll most likely not adhere just pop off. Nice plane by the way![8D]
