RCU Forums - View Single Post - Thrust Incidence on electric v -tail glider
Old 03-09-2008 | 02:46 PM
Thomas B
Default RE: Thrust Incidence on electric v -tail glider
If the V-tail joint is clear of any fuselage on top and if the tail panels are flat, you can generally just park the incidence meter on top of the joint and get a reading, if you can retract the adjustable ends enough to both fit on top.
