RCU Forums - View Single Post - CMP SUPER CHIPMUNK 120
Old 03-09-2008 | 09:29 PM
kid chuckles
Default RE: CMP SUPER CHIPMUNK 120
Have the smaller 40 size from CMP it is an alright plane. I did not care for the motor locations not being marked or a template or something. Did not care for the hardware for the elev. and rudd. asume it will be the same. Wooden dowls you must drill and mount metal rods to. Nothing prebent. Need to have a bender for sure. I like the fiberglass fuse. Hate the landing gear. Might as well beef it up or at least put a good coat of epoxy werever the rod sits and cover it in a layer pretty thick or it will rip the wings were it mounts out and do a good bit of damage. The Motor area you will also have to set your thrust deg. Very good looking plane and flys pretty good lands a little hot but overall pretty plane. Just some stuff i went thru with the smaller version.
