Originally posted by jldecarlo
I have had great luck with learning to hover with the G2 plane "Cap 232 - 2x" which is very easy to hover.
I have not had much luck with elevators or harriers with this plane. Is there a G2 plane file that works well for a harrier/elevator trainer? If so, where do I find it?
Leonard
Hi jldecarlo:
I also use this plane on G2, and I can harrier with it. The CG is about -4, and the surfaces are turned up pretty high. I think I'm using the OS 1.60 for the power....but I'll have to check.
