RE: Repair help
is it the pin next to the chassis or the one that holds the hub to the lower arm?
if it is the one next to the chassis there may be a e-clip on both ends or you need to take the bumper off and it will reviel the pin. if it is what holds the hub to the lower arm there is a grub screw on the bottom you need to take out then you push the pin out with a little screw driver or something. if it is neither of these take a pic of what you are talking about.
