RE: WOT- Servo Feedback
You may be binding the servo. ie.. the servo still has more travel but the throttle is all the way open already.
If your radio has the capability you can try end point adjustments, if not try moving the control rod in 1 hole on the servo or out one hole on the carb.
This is only one possibility, there are others.
