RCU Forums - View Single Post - Ignition sensor TDC question
Old 03-10-2008 | 07:00 PM
karolh
Default RE: Ignition sensor TDC question
I use a rather crude method of installing a depth gauge through the spark plug hole and resting it on top of the piston in conjunction with a degree wheel, and the lowest measurement on the gauge is TDC. Rocking the prop hub a little each way without any movement from the piston give me a zero point.
I'm quite sure that someone will chime in and give a much more accurate way of doing it.
Karol
