RCU Forums - View Single Post - Eletronic engine syncronizer **SUPPORT **
Old 03-10-2008 | 08:04 PM
  #560
Mac Hodges's Avatar
Mac Hodges
Default RE: Eletronic engine syncronizer **SUPPORT **
Bill,
Got everything working. Really maintains the rpm between the two engines when moving the throttle slowly up and back. Move the throttle a little faster and it seemed a little slow to syn the G-26s. Went up one step and then another......I'm at the LED 1 and 2 on, LED3 off, LED 4 on now. Seems better, still no oscillating. Thought I would try next step even thought directions indicate my setup shouldn't require that. Any thoughts?
I have all my nine channels in use so don't have a channel for the Aux. connector. I would like to try the Sync Defeat mode. I have Aux 4 turning on a landing light. Could I use a Y on this channel and turn the light on and that would also turn the twinsync off at the same time?
When doing a loop and throttling back to say, half throttle, on the downhill side it seems the engines are going to nearly idle. I assume the unit is reading rpms that are spooled up by the dive and cutting power to maintain the rpm?
Mac
