Official Storm Thread!!!
If the front end is diving regardless of throttle input in the air, is the back of the chassis slapping the jump prior to take-off? Thist will cause the problem you have. I would look at the back of the car first. What springs and shock oil are you running? What spring preload do the shocks have? Are you using the suspension travel limiters?
Good luck.
