ORIGINAL: Zi-Chun Lin
ORIGINAL: riot3d
If they available the 160~170 size I will order one!!The quality of X-treme composit much more better than oxai
Z. C.,
How are you, how's your Adventure?
You must be a buddy of Nuttawut from X-treme. Appearance wise, my ProLine from them is worse than my Astral XX ...
Hopefully, I will have a chance for test flight either this Friday, or, early next week.
I have the feeling Oxai will not produce the Altair. According to Naruke, the Altair and the Aries is the same except the anhedral stab and the dihedral on the wing, and the reason why he offers them both is not everyone likes the anhedral stab.
Adrian
Hi Adrian
The biplane is not good as our imagine!!!Not easy to control!!!
the Advanture I have now is second one.The first one was crash!!!
What happen for your proline???My proline look almost thesame Japan made!!
That's why I want X-treme product don't want oxai!!!
Alex told me about your first Adventure.
So, you have a X-treme ProLine as well? Mine is one of the first five prototype imported by BVM, not only does it have a center seam on the outside of the fuse, the seam is also very rough, Especially, the two fins on the bellypan, if you slide your fingers across the fin on a cold, dry day, it will cut open your skins. In addition, mine came in slightly over 5 kg.
I have notified the problem to Akiba. According to him, the ones that goes to Japan is under 4.8 Kg. Therefore, you probably have the actual production model.
Keep me posted.
