RE: Air Bleed Adjustments Opposite High End?
That's right. Opening an air bleed adjustment screw leans the mix by allowing more air into the carb. Most air bleed carbs I've seen need to be run with the air bleed completely open or the air hole even drilled out with the next-size-larger bit. They tend to run rich.
Dr.1
