RCU Forums - View Single Post - FLy Eagle Jet Models
Old 03-11-2008 | 06:17 AM
  #678
Jgwright
Default RE: FLy Eagle Jet Models
Hi Jeremy
I am still waiting for the electronic valve so the full install pictures will be a few days. It would not be easy to install servo operated valves as there is so little room. The engine bay is finished though. I have included a picture of the pipework under the first equipment plate.
The fin is quite thin and I decied to use a Hitec HS125 thin wing servo that I have used often before. I have used these for aileron servos on 44 powered models as well as the rudder. There is no doubt a better servo, but I had one of these available and have used them before. I will be running at 6v. I am using the new Futaba brushless digital 451 servos for the elevons and canard. This is probably overkill but wanted to give them a try.
John
ID:	900629   Click image for larger version
