RCU Forums - View Single Post - Dual Carbon Horns
Old 03-11-2008 | 06:47 AM
BaldEagel's Avatar
BaldEagel
Default RE: Dual Carbon Horns
We now have to do the same procedure for the rudder, I have found that on the ones I have done the servo arm supplied does not match the rudder horn supplied, so you will need to make the rudder horn to match the servo arm you wish to use. Using a similar method to the horns already done make a template for your rudder horn, thats the easy bit done, now on to the cutting.
Mike
ID:	900651   Click image for larger version
ID:	900652   Click image for larger version
ID:	900653   Click image for larger version
ID:	900654   Click image for larger version
