RE: Air Bleed Adjustments Opposite High End?
I've always said that, "Scar". Basically, I just do not like air bleed carbs. The low end adjustment is gross and not fine enough to get a really good transition or a reliable idle. Two-needle carbs are found on more expensive, more powerful engines, and for a good reason.
Dr.1
