RE: 35% Sukhoi - DA85 Build
Well I got the ignition switch and the DA in last night. I was able to use a charging switch which allowed me to use the existing cut-out on the starboard side of the fuse. I will mount my ignition module on the rt side of the engine box in some black foam that I got from Lowes. Its the stuff you use on plumbing. I'll be mounting my RX next then setting my elevators and rudder last. I'll mark my CG on the wing tips and leave the batteries and rudder servo loose until I can position them to make her slightly nose heavy.
