RCU Forums - View Single Post - scale hinges
Thread: scale hinges
Old 03-11-2008 | 09:18 AM
Closterman
Default RE: scale hinges
I made the hinges on the tail surface of my Beaver and PC-6 with plywood and brass tube. You can see it a little bit on this pics : https://mraerodesign.securicom.ca/fr...pg&ProduitID=2
They are removable and very strong. You can download the Beaver manual the see how they work exactly and how I install it on the model..
https://mraerodesign.securicom.ca/co...v3%2Djpg%2Epdf
I use 1/8" thick plywood (5 ply aircraft grade) on each side with 1/8" balsa on center to get a thicker hinges assembly.
