RE: Eletronic engine syncronizer **SUPPORT **
Dan,
The twinsync is powered by the receiver (red wire from the throttle channel). So if the receiver is on a seperate battery then you need to pull either the red wire from the throttle or red wire from the BECs. You can power it from either one.
BTW you are one of the 21 people and will be getting an email from me in a couple of hours to check something on your unit.
