RCU Forums - View Single Post - Ignition sensor TDC question
Old 03-11-2008 | 11:26 AM
rlmcnii
Default RE: Ignition sensor TDC question
Doomking,
You do not need to find TDC. The following works well, as recommended by RC Showcase, for positioning the pick-up on a 40 RV. The RE may have different timing, I do not know.
Place the engine on your bench with the prop-drive facing you and the exhaust port down. You will be looking directly down on a web cast into the side of the case. Measure 6mm to the right of the center of the web. Make a mark there. Mount the pick-up centered over that mark.
You got it!!
