RE: Engine Problems..
Usually you can slide the con rod and piston out by taking off the backplate and sliding the end of the con rod off the crankshaft. If the crank still pushes teh piston up you can put a zip tie or other type of plastic in the exhauset port, rotate the engine and the piston will push up against the zip tie and that will push th sleeve up.
