RCU Forums - View Single Post - Ignition sensor TDC question
Old 03-11-2008 | 02:52 PM
Tired Old Man
Default RE: Ignition sensor TDC question
Funny that nobody has mentioned using a dial indicator. That's the most accurate and can be obtained rather inexpensively from some of the tool supply houses. You'll find it useful again the first time you crash and you want to check to see if the crank was bent...
