RE: Exceed-RC Raptor G2 Keeps Spining
Hi crew, I just got my raptor on friday. I love it, I cut my teeth on the blazing star. A little hint, You have got to reset your transmitter after every charge. Put your transmitter for tail roter alittle to off center (right) before you turn on the transmitter. Keep your Raptor low to ground on lift off to adjust torque, you will have to keep adjusting through flight, keep adjustments minor. If you are lucky enough to use a gym or large closed room, I mean a large area it helps build skill.
