RCU Forums - View Single Post - Explaining CG
Old 03-11-2008 | 09:38 PM
bruce88123
Default RE: Explaining CG
With some "pusher" aircraft the engine and fuel tank are located BEHIND the CG. In these cases you want to balance with a FULL tank. As the fuel burns off the balance will turn to nose heavy which is preferred. ONLY balance with a full tank if the tank is located BEHIND the desired CG.
