ORIGINAL: jumper666
You might let it slip a tiny bit aft but not by more than a mm or two. Do everything you can to move weight forward.
I've flown it without problems with the C.G. set far MORE than a "MM or two" back.
I've flown it at the 60 & 70MM, though the latter is too much.
