RE: Winter Break in Suggestions
Or you can take a sock, or tin foil and wrap it arounf the heat sink. This will act like a blanket and will help raise the temp of the engine, but check the engine temp often. And as said if the engine hasnt reached high enough temps then you will due more damage to the engine then anything really.
