ORIGINAL: seemefly_1
Another thing about tower fuel is that it is a quart. I run thought at least that on a good day and I have one plane.[X(]
Tower sells quarts and gallon cases.
The quart containers are small enough so as not to qualify for the hazardous materials surcharge ( $40.00 I believe!!! ).
The gallon containers are over the limit so if you do this you are best off purchasing four gallons, as the charge will be applied against a whole case ( 4 ).
It's still very expensive considering that your LHS does not get nor pass on the hazmat surcharge.
