RE: need help
If you adjust the tracking in idle up, does it look off in normal? I think the increased RPM of idle up makes it more sensitive to tracking error, so it may look OK in normal but get worse in idle up. If you get it right in idle up, I'm guessing normal mode will be ok also.
