RCU Forums - View Single Post - Super Skybolt ARF
Old 03-12-2008 | 09:51 PM
  #449
opjose's Avatar
opjose
Default RE: Super Skybolt ARF
Check the cap screws on the engine. It sounds like you have a loose one or two.
It's a good idea to also check and tighten the screws after the first and second tank of fuel, as they come loose with the heat initially.
I balanced my Skybolt as per the recommended C.G.
I've found this to be nose heavy. The C.G. can stand to be moved back a bit from the recommended.
I'm running the same setup as you... but I installed the battery just behind the firewall... wrong move.
