RE: Resistor Wire and Resistor Plugs.
Resistor core wire with a rubber spark plug cap and a resistor plus is the correct combo.
Wire lead with shielded metal cap and resistor spark plug is also correct. But for the engines that use the CM-6 plug, full shielding and metal cap is needed because the CM-6 is NOT resistor..
