RE: Zlin EP - What is the CG?
opjose - your solution did not occur to me - I have only built 8 planes so far and hadn't encountered that issue before.
Could'nt re-size without cutting an access - which is obviously what I ended up doing.
Thanks for the tip on the connector pin inserts.
