ORIGINAL: mrbonk
ORIGINAL: Furadi
ORIGINAL: mrbonk
5/7/3 didn't work for me. Way too much understeer. I've gone to 5/5/3 and will probably drop the rear down to 1 or 2. I can't seem to get enough front end traction through the turns. I'm considering losing the front sway bar too, if the thinner rear diff oil doesn't work.
What caster blocks are you running?
The 22deg ones.
Have you tried the 20's or 18's? I felt there was to much understeer in my Hyper so I switched to 18's. It went form turning wide, to spinning out if I cut the wheel to hard. Its a HUGE difference. Just make sure you use red loctite on those bottom knuckle bushing screws.
