RCU Forums - View Single Post - building a speed cowl
Old 03-13-2008 | 10:50 AM
Mike Connor's Avatar
Mike Connor
Default RE: building a speed cowl
NACA testing int the 1920's showed an engine cowl alone could increase the speed by over 10%. You must consider that most of these were radial engines with multiple cylinders. The round cylinder is very bad for drag so it seems that even adding an extension off the rear of the cylinder, giving it an airfoil shape, would increase speed some.
